It is currently Tue Oct 07, 2025 5:42 am
PostPosted: Tue Dec 14, 2010 8:06 pm
IM SO F!?@KIN PI^"ED I COULD FCUKIN MURDER A PIG.
it seams my car hates me,an why wouldnt it,its not like ive spent over 3k on it an taken care of it an brought it back from certain death an loved it like a child and polished it and made plans for our future and run it on the best fuel...................im not sure how much more i can take.......am i being tested? did i do something wrong? its on its third gearbox now an its just eaten it again, its lost 3rd an 4th an im loosing all respect for it...........we could try going to counceling,i'd try i really would but without another gearbox i carnt get there. i just dont know what to do with it anymore. maybe sell it an buy a ford. :cry: :( :cry:
PostPosted: Tue Dec 14, 2010 10:43 pm
what gearbox's have you purchased?!
3 boxes is just plain mad, im on 120k on the same box the car came with , just change gear smooth and slow but if you need a good second hand box i would recommend some people over here as 3 is just plain unlucky.
PostPosted: Wed Dec 15, 2010 1:07 pm
define gears gone
with the engine off no amount of rowing will select 3rd or 4th
with the engine off i'd give oxbridge a good run on the river but I can get a gear
with the engine running, stationary clutch in no 3rd or 4th all others fine
as above but crunches into all gears
everything fine but can't get gears when moving
i'd suggest if 3 boxes have died the same way something is wrong with the shifter
PostPosted: Wed Dec 15, 2010 8:58 pm
first gearbox in the car when i had it back in feb this year,this had 2nd 3rd 4th syncro problems so i brought a used but apparently very good condition st205wrc gearbox an transfer. fitted this when i fitted the st205 head gasket an new exedy clutch an other new bits,then first run out the 3rd gear syncro was worn so i was more than abit upset an pi55ed at that,but i lived with it for another 5months or so until
the transfer box spat its dummy out an swarf went round the whole box............so.........i brought a st185 shell which came with a gearbox an transfer but no history, so i dropped the oil which looked used but very good an decided to take a chance an wang it in as it had'nt really cost me anything, and it was fantastic no noises no crunchy syncros just a good box. then when the gear select went fairly stiff coming home from work i knew deep down that i was going to be shafted once more and then it happened, i went for 3rd...........nothing......4th..........nothing. still got the rest of the gears as a sort of runner up prize but its left a rather bitter taste in my mouth.
and now i carnt even take the micky out of my landrover lovin friends about gearbox problems!
PostPosted: Wed Dec 15, 2010 9:20 pm
uoh yeh............it moves the selector fork but it just doesnt move anything else.
and im in the uk, shropshire,north wales.
plan is to buy a very good st205 box
PostPosted: Wed Dec 15, 2010 10:39 pm
Try giving Mark Mills a call (http://www.st205parts.co.uk/) - he's near Gloucester and should be able to sort you out a decent gearbox.
PostPosted: Wed Dec 15, 2010 10:40 pm
If you had loads of dwarf in the oil from box no. 2, what did you do to clean out cooler and pipes on the car?
PostPosted: Wed Dec 15, 2010 11:02 pm
the gearbox that came with the shell,box number 3, had its own cooler and pipework so i replaced the lot.
PostPosted: Thu Dec 16, 2010 9:56 am
Your using correct grade gearbox oil right?
PostPosted: Sun Dec 19, 2010 11:54 pm
i have a gearbox and transfer if your interested...
PostPosted: Mon Dec 20, 2010 9:32 am
Maybe the shifter and the shifting cabels are worth to have a look for and don´t forget the front and specially the rear engine mounts. If they are worn out the shifting will be problematic as first.
PostPosted: Mon Dec 20, 2010 5:55 pm
If Mr Burt doesn't want it, I might be interested. How much?
1991 Jap ST185A
ST205 Head Gasket.
Some random RV & no-name BOV
Blitz Nur-spec SS backbox
Apexi Air Filter
ST205 Front Calipers - Yes, really!
PostPosted: Mon Dec 20, 2010 7:16 pm
£250 mate
PostPosted: Mon Dec 20, 2010 9:20 pm
That's more than I paid for my car!
Mileage?
1991 Jap ST185A
ST205 Head Gasket.
Apexi Air Filter
PostPosted: Tue Dec 21, 2010 12:42 pm
Good condition, taken from 95k mile ST205,...
