Cheers again boys... story started about 4 weeks back. She was in daily use and one cold morning taking wor lass to work she cut out about 1/2 mile from home whilst sitting at traffic lights. Most odd I thought... she started up ok so I dropped wor lass off and on the way back (one & a half mile done now) she cut out again at tickover at a junction. This time it took a few goes to start up again but I got her home and started asking around what it might be. I felt she was flooding once warm and MartinK suggested the water temp sensor in the elbow so I had a look and found the cold start sensor was broken and thought maybe this is confusing the ECU so I ordered new sensors (not easy to find!!) They eventually arrived so I fitted them the other day.
Now the boogar starts OK but cuts out after a few seconds, sometimes, if I keep the revs over 1500 she will run for a few minutes but as soon as revs drop she tends to cut out. When warm she seems to run ok but it is erratic and I am not taking her out on the road 'in case'
Once when trying to start her, after an awfull lot of cranking... the 4 way flashers came on and the turbo timer, which was switched off, came back on????.
It was then that I noticed the crackling/erratic flashing of the EML at full ignition.
Must be bad earth/contact somewhere so I'll just have to strip and search... oh boy
Previously a UK WRC & a CS
Now...a 13/60 cv herald
,a Honda CR-Z and an Amica
