It is currently Mon Oct 06, 2025 9:01 pm
Post new topic Reply to topic  [ 15 posts ]
 Post subject: Steering Creak
PostPosted: Thu Jan 03, 2013 3:35 pm
My ST205 has been off the road for a little while. When I took it off the road it had a slight creak from the steering rack.
Since getting it back on the road and driving it again, the creak seems louder than it was before.
Has anyone else had this at all?
Any ideas what it could be and how I can fix it?
Cheers!
PostPosted: Thu Jan 03, 2013 4:17 pm
You could do what I do, with the rattles and creaks in mine, Turn the radio up louder :lol: :twisted:
[color=#000080]ST205 WRC 1994
Hybrid turbo
Apexi AVC-R
Apexi Power FC (Not being used ATM)
Apexi Power commander (Not being used ATM)
PostPosted: Thu Jan 03, 2013 4:52 pm
:lol: thats what I'd normally do, but it came up as ad advisory on the MOT
PostPosted: Thu Jan 03, 2013 6:51 pm
Make sure the bolts securing this to the subframe are tight...
PostPosted: Thu Jan 03, 2013 7:58 pm
in the risk of sounding like a noob... where abouts are they located? pretty easy to find once under the car?
PostPosted: Thu Jan 03, 2013 9:52 pm
There are 2 bolts, one each end of the rack in the bottom bolting through the subframe. Access from underneath, above rear of subframe. The bolts are horizontal, heads at the back and semi captive nuts (spike on back goes through hole in subframe) at the front. You can see them if you remove the wheels and look in through the steering arm holes.
PostPosted: Thu Jan 03, 2013 9:55 pm
I had an awful creaking noise coming from the front right, after taking the wheel off there is one screw on a base plate of the suspension. I tightened this up about half a turn and that cured it.
PostPosted: Thu Jan 03, 2013 10:04 pm
The red circles indicate the two securing bolts
Thanks for the picture Mike! :lol:
PostPosted: Thu Jan 03, 2013 10:32 pm
Glad to be of service! :)
PostPosted: Fri Jan 04, 2013 2:22 am
Are you sure its the rack thats creaking? Identifying the location of noises is notoriously difficult, just as Kris about his wheel bearing saga! Never heard of a problem with the rack before. More likely to be suspension related.
PostPosted: Fri Jan 04, 2013 7:28 am
I had a noise from the suspension area... turned out that one of the steering rack bolts wasn't correctly torqued. A cheap suspension fix?!? :lol:
PostPosted: Fri Jan 04, 2013 2:31 pm
looking at the pic that Kris has put up, that is pretty much exactly where the noise is coming from, at the weekend I'll get it somewhere to get it up in the air and have a go!
I'll let you guys know how I get on! Thanks for the help people!
PostPosted: Fri Jan 04, 2013 3:25 pm
Good of you to take your engine out Kris, just to get a picture for CTM :wink: :lol:
Hybrid turbo
Apexi AVC-R
PostPosted: Sat Jan 05, 2013 12:04 am
I hope you find its the cheap 'suspension' fix!
 Post subject: Re: Steering Creak
PostPosted: Sat Jan 05, 2013 11:39 pm
Just out of curiosity, any ideas what the torque figures should be for those two bolts? or is f***ing tight good enough? :oops:
