It is currently Tue Oct 07, 2025 5:38 am
 Post subject: Fuel Gauge Fail ?
PostPosted: Tue Jan 04, 2011 6:28 pm
ok so i dont know if its the cold canadian winter or what, but yesterday i filled up and my fuel needle didnt pop up like it normally does, it actually didnt move at all just stayed at the E mark never moving????
Is this a common issue with a 1994 GT4 ? I dont want to get to the tank to check so im hoping its a burnt out gauge in the cluster, anyone else had familiar issues
car has 143 000 km on it
PostPosted: Tue Jan 04, 2011 6:49 pm
two of my friends had the same problem, one loses the air-ball from the sensor (i'am not sure how he fixed the problem but i'am sure he didn't bought a new one)
the second is not checked yet
PostPosted: Tue Jan 04, 2011 7:18 pm
Have a look in the boot (trunk) under the carpet - inspect the wiring and if ok, undo and remove the sensor from the tank - inspect.
Warning - watch out for the fuel vapour!
PostPosted: Tue Jan 04, 2011 7:25 pm
You should be able to get some idea whether the fault is in the sender without removing by unplugging in the boot and measuring resistance. Also check you have volts coming down from the gauge end. (lack of volts would indicate gauge or wiring problem)
PostPosted: Tue Jan 11, 2011 8:57 pm
perfect, thanks
