It is currently Thu Oct 09, 2025 4:03 pm
PostPosted: Sat Mar 11, 2006 5:07 am
165 clocking
Great every version of four is different,.... :cry:
To make matters worst, the choice of turbo, adds further variance... :roll:
Custom actuator brackets all the way, no universal type... :cry:
The addition of a kenlow to the parts list..is a must. :arrow:
However ....on the good side :D
The reduction of 360 degrees of bends, is an advantage. :shock:
night :wink:
PostPosted: Sat Mar 11, 2006 9:50 am
jon, kenlow is a slimline engine fan, yes? :)
and ill swop you a clocked 165 actuator bracket for those poly bushes i sent gary :)
my friend francis might be calling you later WRT a cossie head rebuild btw ;)
PostPosted: Sat Mar 11, 2006 10:15 am
Andy, yes, similar to Spal. I found through my limited searching that the Kenlow was more expensive that a Spal.
Alan from www.feredaycars.co.uk has said that he would do us a decent price if you drop him a line and mention the DC.
PostPosted: Sat Mar 11, 2006 11:54 am
cool stuff kris, thanks :)
now ive flogged the TD06, i think my likely turbo route is a CT26 from a '90 supra, clocked with a moved actuator bracket
not a bad turbo for £150 off supraman :)
PostPosted: Wed Mar 15, 2006 9:15 pm
Hi
A new revision of the 165..Turbo actuator clocking bracket
Image.
PostPosted: Tue May 23, 2006 7:28 pm
Car Model: ST165
clocked CT20b on a ST185 engine, fitted to my ST165 :D
actuator bracket and installation by datajon:
ST165 turbo 4WD
PostPosted: Tue May 23, 2006 8:43 pm
See that your compressor housing has an extra mounting lug...this is very handy when clocking the turbo.
Looks like the 165 amd 185 turbos have this, but the CT20 does not have this extra mounting lug and thus the mounting for the actuator is a bit more traumatic :(
PostPosted: Tue May 23, 2006 8:45 pm
Gary my son, boy do I have a new clocked turbo install.
It’s my best yet...
I am not talking of a compressor housing rotation, but a complete turn around, it could not make the job in hand any easier..
Even better its Now on paper, which means its on course for construction.
As for straight air intake, it’s the best route yet, one draw back, its only works on 205 ecu and above.
I need to check it out, for being the first of its kind.., its makes complete sense, I stumbled on it, trying to work out how to install two turbo’s and omfg its great, I really thinks it’s a winner..
Look < hint
PostPosted: Tue May 23, 2006 9:03 pm
Car Model: ST165
i saw your new avatar.;) i'll pop over tomorrow for a brew :D
Kris,
Re: mounting lug. I was under the impression that my turbo is a CT20b MD228 hybrid?
ST165 turbo 4WD
PostPosted: Tue May 23, 2006 10:15 pm
Maybe this has the CT26 compressor housing...seems quite a popular route for the turbo rebuilders?
PostPosted: Tue May 23, 2006 11:48 pm
Owens built the Stage 2 Hybrid for my UK ST205WRC with the turbine from my old CT20b and a compressor housing from a CT26.
My JDM ST205WRC has an MD228 which was on the car when I got it so can't really vouch for its origins. Can take some pics if you're interested.
PostPosted: Tue May 23, 2006 11:55 pm
Car Model: ST165
i thought ct26's had ct26 cast on the housing? confused :? :LOL: :
http://img228.imageshack.us/my.php?image=turbo29kh.jpg
ST165 turbo 4WD
PostPosted: Wed May 24, 2006 11:03 pm
Think you are correct Gary, but maybe later or aftermarket compressor housings seem not to bear this mark sometimes?
PostPosted: Thu May 25, 2006 7:36 am
All Ct26's have CT26 writrten on the compressor housing.
All Ct20b just have "Toyota" written on the compressor housing.
Turbo builders prefer t start with a Ct26 as teh CHRA has a larger shaft hole and hence it saves machining out the CHRA. CT20b's also have nasty ceramic parts on teh turbine wheel and hence thw whole wheel & shaft need to be replaced. All possible but it is cheaper to give them a Ct26 to start with!
