It is currently Tue Oct 07, 2025 1:04 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Fri Aug 04, 2006 9:40 am
I will weigh a nankang and we can subtract teh difference.
PostPosted: Fri Aug 04, 2006 12:36 pm
<anorakmode=on\>Don't forget to measure the tread depth as well so we can correct for wear<\anorakmode=off> :lol:
PostPosted: Fri Aug 04, 2006 7:08 pm
no need - woudl have bene teh same nankang fitted when Kris weighed it as I have in teh garage. Oh I also have weighed a full weight/traed Nankang so will all be sorted
PostPosted: Sun Mar 09, 2008 3:20 pm
Just measured the wheel & tyre weight of a St185 wheel with orginal Pirelli P6000 tyre with 4 mm of tread. (must be a collectors item by now!)
I nearly fell off my chair.... 19KG!
Wheel = 15" x 6.5"
Tyre = 215/50/15
PostPosted: Sun Mar 09, 2008 3:55 pm
OZ Chrono weights; Click here
Brand: RAYS Engineering
Model: Volk Racing TE37
Size: 17x8.0J +35 offset
Weight without tire: 7.0 kg
Weight with 225/45/17 Toyo T1-R: unknown at the mo
PostPosted: Fri Apr 11, 2008 9:50 am
Brand: TTE
Model: Not Sure, 2 piece split rim
Size: 17 x 7.5 +35 offset
Weight without tire: -----
Weight with Toyo Proxes T1-R 235/40 ZR17: 19.5Kg
Brand: Momo Italia
Model: Not Sure
Weight with Toyo Proxes T1-R 235/40 ZR17: 20Kg
PostPosted: Tue Jul 28, 2009 10:52 pm
OZ Chrono 17 x 8 5 x 100 PCD and ET35 offset are 20.9kg's each with 215/45/17 Goodyear Eagle F1 tyres
PostPosted: Tue Jul 28, 2009 10:54 pm
Revolution Millenium 18 x 8, 5 x 100 PCD, ET35 weigh 23.5kg with Toyo 225/35x18 tyres
PostPosted: Tue Jul 28, 2009 11:01 pm
I really would not have thought the OZ Chrono's would have been that heavy!
Need to weigh my superlegerra's
PostPosted: Wed Jul 29, 2009 8:08 am
Brand: Rota
Model: GTR
Size: 18 x 8 +35 offset
Weight without tire: 8.9 Kg
Weight with Goodyear Eagle Assymetric: unknown
ST205 WRC
PostPosted: Wed Jul 29, 2009 4:17 pm
Brand: Sportmax
Model: 050
Size: 17x9, 38 offset
Weight without tire: Est 9KG/ 20lbs
Weight with tire: 21.7kg/ 48lbs
Tire specs: Marangoni Zeta 255/40/17
Note: stock 185 wheel/tire weight on the same scale came up 18.1kg and 40lbs.
My goal for my next wheel tire setup is to get the total weight closer to the stock range. I am looking at wheels in the 7.26kg/ 16lbs range and tires in the 10.4kg/ 23lb range. Hopefully combined with a lighter front brake setup I should have some nice weight saving.
Coldiron (Cold - Iron)
http://www.noritoy.com
PostPosted: Sat Oct 31, 2009 10:59 pm
courtesy of Nigel (Muddywater)
OZ Chronos 8J x 16" PCD 5x100 ET38
fitted with Kumho Ecsta KU31 tyres 225/50x16
Weight = 21kg (each)
Team Dynamics Pro Race 1.2 8J x 18" PCD 5x100 ET30
fitted with Toyo Proxies T1-R tyres 215/40x18
Weight = 19.5kg (each)
Standard 6-spoke Toyota Wheels 7.5J x 16" PCD 5x100 ET45
fitted with Dunlop Direzza 02G (track) tyres 225/45x16
Weight = 17kg (each)
