It is currently Mon Oct 06, 2025 9:20 pm
PostPosted: Tue Apr 24, 2007 1:35 pm
The choices are quite simple. TRD springs and dampers, whiteline adjustable rear ARB and a good check of all the suspension linkages to eliminate any play. Then throw an average alignment into the mix and you're going to have a car that handles much better than stock for minimum (lolololololol) outlay. For a slightly more adjustable setup then go with the Tein coilovers
Good advice
You'll end up with a car that handles beautifully (within the intrinsic chassis limits) on track but is a right pain in the proverbial on the potholed barely maintained surfaces that are the UK roads
Never was a truer word said :?
My standard(ish) ST205 with stock suspension, 16" wheels and 55 profile tyres is great for dealing with council potholes and so-called 'traffic-calming' features but I wouldn't take it anywhere near a track :)
PostPosted: Wed Oct 28, 2009 4:16 pm
Just trying to setup angles to:
front toe 0mm
front camber -1°50' dx and -1°50' sx
rear toe 0mm
rear camber -1°00' dx and -1°00' sx
Problem is that is very difficul to setup front camber, because just slightly touching the banana arm will change it a lot!
But is it normal ?!?!?
Wolf
Wolf_Tm
TM 250 enduro 2 stroke
PostPosted: Wed Oct 28, 2009 4:33 pm
that doesn't sound normal to me. What readings are changing?
There is quite a lot of deflection in the suspension due to the oem rubber bushings but it should take quite a bit of effort (think hanging off the end of a breaker bar type force).
Sounds like there may be a bit of play in something somewhere
PostPosted: Wed Oct 28, 2009 4:49 pm
Front dx & sx camber values...
I don't really know.... all the arms are new! :?
Wolf_Tm
PostPosted: Wed Oct 28, 2009 7:11 pm
Can you be a bit more precise on the "touch" and "change" aspects
Do you mean you rest your hand on it and camber changes by 0.5 degrees for example
Does camber change both sides when you touch one banana arm?
Does the toe change at the same time?
Are you setting it up with the suspension loaded i.e. cr on wheels?
PostPosted: Wed Oct 28, 2009 10:55 pm
Yes, just lightly pushing up the banana, its camber changes...
IIRC no...
Yes, car on wheels...
Wolf_Tm
PostPosted: Thu Oct 29, 2009 11:37 am
it's got to be a measurement issue imo.
If pushing the banana arm one side makes the measurements change both sides **at the same time** then I can't think of another reason unless the whole subframe is loose - I imagine you'd notice that!
