It is currently Tue Oct 07, 2025 1:01 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Nov 04, 2011 6:32 pm
thats Wheel HP @ 1.2 bar , not an aggressive map he said as its still on stock pistons
edit : i meant Flywheel HP . the sentence doesnt atually make sense without it tbh lol
PostPosted: Fri Nov 04, 2011 10:32 pm
thats around 460bhp at the fly if i calculate correctly... rather impressive figure for a 3071 at 1.2 bar boost what kind of other mods are on the car as that is most impressive.
most 3076 turbo setups wouldnt get that power at 1.2 bar
PostPosted: Sat Nov 05, 2011 7:46 pm
Hi daz ive removed the C-ONE 4 branch but see your sorted now ill stick it on the Bay.
PostPosted: Sun Nov 06, 2011 12:27 am
That is a flywheel BHP figure.
You are making 345 lb/ft at around 4500rpm which is about right for a flywheel figure at 1.2 bar. If you are making 345 lb/ft at wheels it would be around 400-430 lb/ft at 1.2 which is unheard of on a 2.0 litre turbo (unless you are are running rocket fuel??)
Nice safe map there from the graphs though so IMHO there is plenty left at the same boost with forged pistons.
PostPosted: Sun Nov 06, 2011 8:52 am
thought it seemed rather high for a 3071 on a 2l.
most of them dont seem to hit 400bhp fly without a good 1.5+ bar boost.
still good though and as you say, when or if forged are applied you have the turbo to get some good power
PostPosted: Sun Nov 06, 2011 1:38 pm
oh lol yeah its fly my bad haha
PostPosted: Mon Nov 07, 2011 4:02 pm
Can anyone tell me what sort of boost the stock head gasket is good for?
PostPosted: Mon Nov 07, 2011 4:56 pm
stock st205 ? or st185 etc
st205 can take lots as its a 4 layer steel jobbie
st185 is made of paper over 1 bar and your pushing it ( could be wrong though as i never had one )
PostPosted: Mon Nov 07, 2011 5:41 pm
nine numbers and a nice install indeed
Just add 264 cams for somewhere close to 400 HP :twisted:
PostPosted: Tue Nov 08, 2011 9:11 am
I'm still tempted to horde it and fit it when it goes bang! Any pics, plz PM me. Thanks!!
351PS, 454Nm ST205 WRC @ 1.2bar | Stock engine
PostPosted: Tue Nov 08, 2011 9:13 am
Intrigued!
PostPosted: Tue Nov 08, 2011 3:26 pm
What intercooler are you using?
Numbers are nice.
I recently got 322 at the fly on my CS with GT3071 @1,2 bar on stock internals. 280 @the wheels.
I have some upgrades to make and hope to reach the same number as you on my GT3071 safe map @ 1,2 bar.
ST185 CS #1845
PostPosted: Tue Nov 08, 2011 6:58 pm
Intrigued!
Cams will help stop the torque rolling off at higher rpm so HP goes up "for free"
It will require a remap though as the fuelling will be altered
PostPosted: Thu Nov 10, 2011 6:19 pm
Welshman,
The ST205 gasket. We were going to run the 3071 at 1.2bar to start and then up it gradually. Lots of different advice regarding what the pistons etc can take, quite tempted to R&D by increasing it progressively until it fails!!!
Heard the ringlands are weak but then people used to say all sorts of things about other cars that wasn't so. If it's not detting it shouldn't be an issue unless the in cylinder pressures are so high that it crushes the ringlands, but we'll see.
Cheers
Nito
PostPosted: Thu Nov 10, 2011 8:53 pm
EGT and Det kills the pistons , they shouldnt get crushed so to speak imo .
some have ran 400 on a stock st205 engine but thats very often on a japanese map and probably overfueling to keep things cooler .
