It is currently Thu Oct 09, 2025 5:16 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Apr 28, 2012 7:55 pm
Ok, thanks anywho Sirius.
Cheers for the ideas Chris, think I'll get in touch with someone who can weld aluminium and stick a new top with pressure cap on, as you said, got to be the best long term fix.
PostPosted: Sat Apr 28, 2012 10:01 pm
e.g.
http://www.ebay.co.uk/itm/ALLOY-RADIATO ... 43af35a0e6
This is the end result you're after:
PostPosted: Sat May 05, 2012 10:58 am
Looking good dan Ill have to take a look in august
PostPosted: Mon May 07, 2012 4:18 pm
Another big thanks to Chris! Finally got rid of my power steering leak! Also got the fuel pressure regulator fitted.
Managed to get the header tank pressure relief sorted on friday with my local mechanic. Best bit being it works!! So hopefully no more blown hoses/radiators lol.
Still have an interesting problem with the Speedo where it's reading about 1/3 "out". Think it maybe as I now have a 185 box so changed the sensor with my old 205 box but still the same thing.
Was booked in for a mapping session tomorrow morning however Ryan is stuck in Denmark lol. So will be wednesday morning now.
Uploaded with ImageShack.us
PostPosted: Mon May 07, 2012 6:58 pm
The Fuel pressure regulator kit came with some very shiny attachments which didn't fit the 3s fuel rail, no correct attachment for the fuel rail, hose too short and no instructions.
Thanksully, I still had the banjo fitting from my old adjustable FPR that I ditched. Using that plus the old return pipe allowed it to fit - just. The pipe length didn't allow it to reach anywhere to bolt it on properly so for now it's cable tied to the strut brace, along with the unused bits which were so shiny they just had to be put under the bonnet to look important.
PostPosted: Mon May 07, 2012 11:08 pm
what make of FPR is that?
PostPosted: Tue May 08, 2012 6:20 am
Unbranded ebay job for £30
http://www.ebay.co.uk/itm/NEW-TOYOTA-MR ... 587e99fbc5
vs
http://www.tuningdevelopments.co.uk/pro ... cts_id=918
PostPosted: Tue May 08, 2012 6:12 pm
Heres a couple pics of ur car that i took on saturday :)
P.S look at that angry sheep in this picture on the left lol
WOW so many GT4 in one place :P
PostPosted: Wed May 09, 2012 8:32 pm
Well, mapping this morning went well. Ryan got it all setup, set the fuel pressure regulator to 45psi and started mapping. I now have the option of boost controller off, so 0.7,0.9bar ish which is a little shy of 300 for pottering about. Low boost at 1.1bar which was about 320 for spirited driving. Then Hi set at 1.3bar which is the 345 as below.
I was advised not to do a high speed run i.e. 4th and 5th gear in hi boost as it will put too much stress on the block, rings etc. So keep it more for the odd bit of extra power in 1st, 2nd and 3rd.
He also said if I was chasing numbers I could push it a bit more (the injectors are maxed out at 345bhp/ 45psi) but said the standard wiring is not great and of course will put even more wear on the pump itself. Given it's my daily driver we left it as is.
Again, many thanks to Chris, as without his help the car certainly wouldn't be at this point now :)
Few pics and mod list..
Comparison from 08/2011 to todays map..
Current mods
--- Engine/Cooling
* JSP Ventilation Relocation (VR) KIT
* JSP Shortened Throttle Cable
* JSP 4" SAI Lagged
* ITG Maxogen Air filter - Custom size (rated to 380bhp)"G60 / JC60/99TNB"
* Aussie down pipe Lagged
* Cold air box
* Varley Red Top 25 Battery (relocated)
* EVO 7 Intercooler / Tuning Developments pipe work, gold tape+lagged hot bits - Clocked turbo
* X2 12" Spal fans on radiator
* FMIC - Evo 7 core, TD pipe work, clocked turbo
* Power steering cooler relocated with copper lines using Old Jap spec oil cooler
* 13 row Mocal Engine Oil cooler setup (90degree opening temp) + HKS Hybrid oil filter (04/12)
* UK spec gearbox oil cooler/ pipes relocated
* Lower temp thermostat (76°C)
* Header Tank/Swirl pot setup with Toyota Forlife/Redline Waterwetter
* Forge re-circ dump valve
* Tuning Developments 255lph fuel pump
* Fuel pressure regulator set @ 45psi
--- Chassis/Suspension/Drivetrain
* Exedy Twin plate clutch and flywheel (04/12)
* Blitz Nur Spec R stainless exhaust (lagged past sump)
* JSP Precision Shifter Bush Kit
- Poly Gear Linkage Bush kit
- Solid Shifter Base Bushes
* RT performance front/ Rear 3point strut braces
* TRD spring kit -25mm
* TRD 4 Way Adjustable Front shocks
* KYB rear shocks
* TRD top mounts Front
* TRD top mounts Rear(10/2011)
* Polybushes - Banana arms/Rear full set/Rear subframe/diff mount (08/2011)
* Whiteline adjustable rear anti roll bar fitted (on medium)
* TRD front discs
* Red stuff pads all around
* 17" 235/610/17 Dunlop Slicks / Ultralite Atec 7 Spoke White
* 16" 225/55/16 Eagle F1 / 3 Spoke Standard Alloys White
* 16" 205/55/16 Part worns / 3 Spoke Standard Alloys Silver > White
--- Interior
* Greddy Boost gauge
* Greddy Oil temp gauge
* Momo Millennium Evo steering wheel
* TRD gear knob
* Hyper A pillar twin 52mm
* Hyper sports floor mats
--- Exterior
* Custom WRC decal set by Skewer (Mook)
* Genuine TRD adjustable Spoiler
* 4mm Mud Flaps (MSA reg's)
* Aerial removed
* Black TPI XR steel wheel nuts & locks
* Clear side repeaters
* Late spec rear lights
--- ICE/Electrics
* Apexi Power FC ECU (Mapped by Ryan @ 2Bar tuning 08/08/2011 / 09/05/2012)
* Greddy Profec B Spec 2 boost controller
* Kenwood 8" KFC TC200 Speakers (front)
* Alpine 6" x 9"s SXE69C2 (rear quarters)
* Spree L.E.D Dash kit
* Spree L.E.D Sidelights
* Clifford Concept 650 alarm
* HKS turbo timer
PostPosted: Thu May 10, 2012 12:19 am
Thanks for sharing your experiences and dyno traces. Also, sounds like you got some very sensible advice from Ryan at the mapping session.
PostPosted: Thu May 10, 2012 4:37 am
Looking good dan I'm glad you got the figures you expected, so is that it for now then or have you still got other things to do?
PostPosted: Thu May 10, 2012 7:33 am
Lol, more or less done for now Si :)
All I have on my list now is,
Refurbish my 3 spokes and that X1 7spoke I wrote off
Roll Cage (Next large buy)
Coilovers (maybe one day but happy with current setup)
Replace engine with forged IF it blows up sometime lol :)
PostPosted: Fri Jul 20, 2012 7:49 pm
I have ringland failure...
Thats all for now 8)
PostPosted: Fri Jul 20, 2012 9:06 pm
Oh s##t!!
Im not 100% sure what ringland is but no it aint good! You been driving to enthusiasticly on your way to ice skating?
1998 mercedes E280- sold
PostPosted: Fri Jul 20, 2012 9:54 pm
Oh s##t!!
