It is currently Fri Oct 10, 2025 4:47 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Jan 27, 2006 12:08 am
Steve, dont forget I have tracked my car in various guises for over eight years now and the engine is still OK. Its only since I fitted the MoTeC and been able to run consistently > 330bhp on track that the problems have emerged. Track sessions tend to be around 20-30 minutes which equates to around ten laps on most circuits.
I wouldn't want to give the impression that you have to mod an ST205 to the hilt to get it to survive on track because that is patently untrue. I suppose if you went out and bought a set of cut slicks and bolted them on then you could run into trouble but you'd have to be barking to do that wouldn't you :wink:
The sooner I get this track day guide written for the website the better!
PostPosted: Fri Jan 27, 2006 12:50 am
I totally agree but you have to be aware of what you're dealing with
The 205 is fine on track providing you don't push the limits
I know you tend to do 5-6 lap stints with an hour cooldown betwixt.
If someone just threw a stock car on track and ran 20 laps I think there'd be a big bang. Mind you most cares will suffer in this way
PostPosted: Fri Jan 27, 2006 1:18 am
ENJOYING.. THIS THREAD
Think I'm still in favour of an oil cooler plus water injection with the power below or around 350. 8)
Anyway forget about the car... 5 laps methinks will be more than enough for my brains ability to cope with the reactions.:shock: Happy just watching the 24hr stuff. :wink:
PostPosted: Sat Jan 28, 2006 1:37 am
hand cut touring car rubber, thats the way to go.. :D
If done well, no one would know, apart from the track times..
not that i am a cheat... but they do realy make the difference..
the down side is they let go pretty quick when they do...great stuff :D
PostPosted: Mon Jan 30, 2006 10:05 pm
Please bear in mind this is a PROTOTYPE and as such it is not finished, not secured and not final!!
But a rough idea is:
More details and info to follow ;)
PostPosted: Mon Jan 30, 2006 10:39 pm
nice job that Kris..
just one thing , I love those ground effect coolers..
PostPosted: Mon Jan 30, 2006 11:16 pm
:lol:
Clearance between a lowered car and the road is tight but it is manageable! It's better to leave the stock suspension on if you plan on dangling the coolers closer to the road :lol:
PostPosted: Thu Feb 02, 2006 1:44 pm
Hi
Quick up date of some pictures. more to come
Will answer all questions to night.
CT26 ID size as shown
Reading stainless steel pipe, that connects to ct26
Overlaying the pipe size to ct26 out
Stainless Steel Pipe from turbo size shown
Hose retainer rings.. will hold pipes at 6 bar.
Top pipe work finished layout
Dump valve, outlet hole, several options to choose from
205-actuator bracket. Revised version 2
turbo to intercooler pipe
Sorry for the delay, a little busy..
Jon
PostPosted: Thu Feb 02, 2006 2:00 pm
:shock: :shock: :shock: :shock:
I want one!!!!
Looks good Kris, was there not enough space to mount the G/B & A/C Rads to the front??
Do I spy a Corolla WRC Manifold somewhere too?? :? :?
ST205 WRC #0002249
PostPosted: Thu Feb 02, 2006 3:00 pm
Why do you want to mount them in front of the IC rad? .....I was quite keen to mount the G/B rad on top of the IC rad but Kris reckons this would be quite fiddly. The easy option is to leave it sandwiched between the IC and A/C rads
Kris, is there something we should be told ? :lol:
PostPosted: Thu Feb 02, 2006 3:16 pm
:? :? Thats what I meant Don, you know what I mean... it's been a long day lol :P :lol: :lol: :wink:
ST205 WRC #0002249
PostPosted: Fri Feb 03, 2006 2:23 am
The gearbox oil cooler requires relocating between the air conditioner radiator and the intercooler, the use of metal pipes are required for connection, due to the limited space between the intercooler and front panel.
The power steering cooler requires repositioning, ample room between the air con/rad and intercooler for fitment, just working out which system to use.
A few options would be:
a small 5 row cooler, with supplied pipe work,
Relocating the stock unit with additional pipe work.
Having problems locating a 3-row oil cooler, cost affectively, awaiting the response of further inquiries.
A 5 row would cost about forty pounds sterling, with another twenty pounds for pipe work and fittings.
Choice of unions type, will change pricing somewhat.
The use of braided stainless hose would make sense, with stainless tubing, yet again waiting for response to inquiries.
I am in the process of working out other possible sources.
A simple work around would be to use 10mm copper pipe, with swaged ends, stainless steel jubilee clips and braided hose, this would allow the use of existing coolers, just relocating and plumbing the piping in. would be the budget route.
I don’t see a problem; it’s a case of going though all options and finding the best cost effective route, with a simple install procedure.
I have a few more images
**edit** two_OH_five
Fixed your last image Jon
PostPosted: Fri Feb 03, 2006 1:48 pm
Jon, you may be aware I'm in the process of completing my on-board sensor array (sorry if this sounds a bit like Star Trek :oops: :lol: ) My intention is to carry out extensive testing of the oil, water and charge cooling during the coming track season. The data will then enable me to make an informed decision on what size rads to fit.
My other objective is to thoroughly test the swirl pot and header tank under track conditions. installation of this has been delayed due to problems with my original design. I have now come to the conclusion that there is no alternative but to remove the ABS and relocate the power steering reservoir to provide room on the wing for the header tank. The swirl pot will also require the battery to be relocated :( .... I was hoping to avoid this.
PostPosted: Fri Feb 03, 2006 2:37 pm
Glad to here that some one else is using a date logger with a hole bunch of sensors.
wow looks like you will be busy...a bit of a job to move the abs system.. for a swirl tank.
surley other ways..
to allow for all the iterms to fit..maybe make they smaller using a replicator lol..
wish you luck. back to work. so cold, need hot meal to stay alive..
PostPosted: Fri Feb 03, 2006 8:05 pm
Hey i want some pipes for my 185.
i have ditched the a/c so i hope to have enough space for all the coolers..
i have a nice B&M cooler that i pilfered from my 5.7 Chevy before i sold it which i could mount some where very easily to cool something..
engine oil maybe or to replace one of the tatty looking coolers that are dangling where the air con once lived..
1990 JDM ST185 Grey.
ST205 head gasket.
ARP head bolts.
ST205 Koyo Rad. (almost)
Front mount intercooler.
Colder plugs.
3" decat pipe.
4 Branch manifold.
