It is currently Tue Oct 07, 2025 12:32 am
PostPosted: Mon Sep 10, 2012 10:22 pm
Just found an interesting article in NZ Performance Car about a 400bhp ST205 with a Caldina side feed plenum. Very tidy looking car.
Full article is here:
http://www.performancecar.co.nz/article ... r-over-156
Meanwhile my spare Caldina manifold and T/B has found its way onto another 400+bhp ST205. Hopefully a full report to follow soon after remapping.
PostPosted: Tue Sep 11, 2012 6:57 am
Clint is actually using the st215 head on a st205 block.
and bhp.. pft..
GT Four Adovansu
PostPosted: Wed Sep 12, 2012 11:27 pm
nice wire tucking in the top pic,
are the caldina manifolds a big improvement,
i suppose it gives better route than the center feed for the fmic pipes
PostPosted: Thu Sep 13, 2012 12:02 am
Mostly the side feeds tidy up the intercooler pipework. I doubt there's much if any performance benefit. You really want to go to ITB's for improved throttle response but that's not cheap :twisted:
PostPosted: Thu Sep 13, 2012 6:50 am
member on OC is saying that the longer runner length is giving more response with the st215 IM.
What conversion multiplier are you using to get from hub kw to bhp? Quite curious as I've never seen anyone state the shootout mode multiplication from the euro rolling road results.
GT Four Adovansu
PostPosted: Thu Sep 13, 2012 9:12 am
DON... why oh why did you have to post a pic of my mungrel next to that stunning white effort....
:lol: :lol:
Hey everyone. Here's a stunner from New zealand.
oh. and here's my mates Mrs...
Oh well. I'll get there...
Full report is as follows.
Adrian at Fensport is unfamiliar with this manifold with regards to the flow characteristics. Therefore without Evidence from the plugs it is difficult to work out what each individual cylinder is actually doing. (rich, lean)
This has resulted in a loss of 1.5-2 degrees of ignition advance at the top end versus the centre feed. Which Adrian knows VERY well.
This unfortunately in turn has raised my EGTs.
With development I'm hoping this can be reversed.
The side feed takes less fuel at low revs and more at the top.
It also changed my exhaust note and screamer tone. Didn't expect that..
:shock:
Drivability has in-fact improved. Off boost it feels closer to a NA.
Spool up is unchanged.
Kick from turbo as it comes on boost is harder so I can only guess (hope) it has improved initial torque.
The car in-fact feels faster. Even though I've lost advance. I thought I was trying to convince myself, but others have commented independently.
In short I'm damn happy with the out come. But I'm not having to keep an eye on everything whilst i'm driving. Hopefully was can have the flow figures sussed by start of November. ready for the next Map.
PostPosted: Thu Sep 13, 2012 12:48 pm
It sounds like data is needed from 4 widebands or 4 EGT's to compare flow imbalance.
I believe Don has his manifold drilled for 4 egt's for this very purpose.
PostPosted: Thu Sep 13, 2012 6:32 pm
yes but itbs are alot easier on n/a cars,
are they on many turbo machines?
what would you use, wrc corolla later manifold?
what are you going using on your build?
