It is currently Wed Oct 08, 2025 7:13 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Feb 15, 2012 9:17 pm
Nice job, I need to do the same on my car when it gets its bodywork sorted.
PostPosted: Wed Feb 15, 2012 10:47 pm
Extremely common to find the sills like this...
occurs when using a 2-ton jack without a piece of wood or similar to protect the sill.
It is now an MOT advisory if the sill is damaged liike this.
PostPosted: Tue Sep 11, 2012 7:59 pm
Well I havnt updated for a while on here, sorry. After alot of measuring and cutting and welding I have finally got the rear cage in place. I am at a cross roads now...do I go with my Evolution hybrid build, or go for an all out rally car...well only I can answer that question, I am torn between the two, I guess time will tell, but I am keeping it on hold until I have made my mind up.
For those wishing to have a go in building your own roll cage, this is a pretty terrific web site
http://www.metalgeek.com/static/cope.pcgi
Removed the little interior plastic support brackets, it leaves a much cleaner looking suspension top.
A template made for the strengthening plates
Plate made from 3mm steel
starting to jig the cage in
starting to weld.....this is the first thing I have really welded apart from minor parts and practice
a bit more
sub frame bolts
sub frame tie bar
a bit more
nearly there
finished for the time being
decisions to make now.
PostPosted: Tue Sep 11, 2012 10:50 pm
Seeing as how you've gone down the half-cage route my vote would be to build the car in fast road / trackday spec. It wouldn't look quite right as a rally car with a half cage. You can tell I'm a stickler for detail :wink: My 2p!
PostPosted: Tue Sep 11, 2012 11:44 pm
Good looking project! Also top marks for building your own cage....our life would be sooooo much easier if we could weld....
The subframe bracing is the one thing i wish we had on our cage....ahh well live and learn. It's only ever going on tarmac anyway
PostPosted: Wed Sep 12, 2012 6:08 am
If I was going to go full blown rally car I would finish the rest of the cage and do the full thing.
PostPosted: Wed Nov 28, 2012 8:22 pm
Getting there slowly
The shell prep has taken longer than I thought it would, although in the mean time I have been learning to melt aluminium and make cast parts.......harder than it sounds with mixed results.
PostPosted: Wed Nov 28, 2012 9:48 pm
seen you casting progress on the celica club looks interesting what sort ofthings have you been casting. have you melted much more than just the metal lol
PostPosted: Wed Nov 28, 2012 10:09 pm
I was going to cast an alloy alternator bracket, but I cant get the recipe right, I need to add some copper but I cant get the mini blast furnace hot enough to melt it....and aluminium alloy on its own bends too easily...at least the types I have tried thus far.
I will be making some new radiator top support brackets and perhaps a bracket of two for various swirl pots, header tanks etc keeping the shapes simple
PostPosted: Thu Nov 29, 2012 1:40 am
Insanity-74 wrote:
Getting there slowly......The shell prep has taken longer than I thought it would......
Sounds familiar, my solution was to shower lots of dosh on it to speed things up but need to take a breather now!
PostPosted: Thu Nov 29, 2012 7:24 am
I don't have lots of dosh to throw at it, plus I want to do as much as I can myself. It's the challenge I have set myself, the only things I don't want to do is spray it and media blast it as setting up equipment etc is just too expensive. Although I am sure I will find one or two jobs I just can't do, rebuild an engine I might leave to the pros.
PostPosted: Sun Feb 08, 2015 8:23 pm
A bit of a catch up.......copied from the past ;)
Today is a good day.
Definitely a great day.
At last I have put colour to car and I must say it looks f'in brilliant, I so love the colour. It goes on very well, is very forgiving and is the perfect colour, love it, very happy bunny today. Well chuffed.......and it's only the engine bay, imagine how happy I cam going to be when I paint the topside :D I will be smiling so much the top of my head will fall off :)
[url="http://smg.photobucket.com/user/nialusa/media/imagejpg1_zpsf6b946f5.jpg.html"]Image[/url]
Only the first layer, a small amount of flating to do, then more colour.
PostPosted: Sun Feb 08, 2015 8:24 pm
A small bit of progress today.
Fitting the front coilovers
[url="http://smg.photobucket.com/user/nialusa/media/Celica%20Rebuild/P1010839_zps325269fc.jpg.html"]Image[/url]
Took a bit of fettling but its all sorted now
[url="http://smg.photobucket.com/user/nialusa/media/Celica%20Rebuild/P1010849_zps030bc291.jpg.html"]Image[/url]
rear coilovers fitted
[url="http://smg.photobucket.com/user/nialusa/media/Celica%20Rebuild/P1010842_zpsb7a8c4f4.jpg.html"]Image[/url]
[url="http://smg.photobucket.com/user/nialusa/media/Celica%20Rebuild/P1010843_zps9e6a99d5.jpg.html"]Image[/url]
as you can see, i dont have much space to work in...need to build myself a bigger garage.
[url="http://smg.photobucket.com/user/nialusa/media/Celica%20Rebuild/P1010845_zps9a7faa48.jpg.html"]Image[/url]
PostPosted: Sun Feb 08, 2015 8:25 pm
The engine is about a year or so away. interior next along with electrics and braking system.
Well, its on its own wheel at last (the other three i had to borrow :) )
Its alot lower than i remember it :lol:
[url="http://smg.photobucket.com/user/nialusa/media/Celica%20Rebuild/P1010852_zps7c76e8c2.jpg.html"]Image[/url]
its alos alot easier to move around :thumbsup:
[url="http://smg.photobucket.com/user/nialusa/media/Celica%20Rebuild/P1010855_zpsdaa29de4.jpg.html"]Image[/url]
interior next....oh joy, not looking forward to the next lot of work at all, maybe i will take a break for a while
PostPosted: Sun Feb 08, 2015 8:26 pm
A whole lot of fun today, i still hate fibreglassing things. Whos daft idea was it to install a roll cage???? :lol: :lol: the top half of the plastics that frames the window will get flocked, the lower half, after a lot more work will get painted a high gloss black, along with the front door lower sections and the bottom half of the dash, dash inserts will get painted a silver.
[url="http://smg.photobucket.com/user/nialusa/media/Celica%20Rebuild/P1010862_zps79717ab2.jpg.html"]Image[/url]
[url="http://smg.photobucket.com/user/nialusa/media/Celica%20Rebuild/P1010860_zpsc2342d37.jpg.html"]Image[/url]
Users browsing this forum: No registered users and 64 guests
