It is currently Mon Oct 06, 2025 7:26 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jan 06, 2013 11:06 pm
I too have seen a large number of nine bob note manifolds
I've generally had pretty good luck getting the turbo to manifold studs out but I always start with lots of heat from a MAPP gas torch
I also removed all of the manifold to head studs using the same method
My routine goes
Soak in WD or a diesel/brake fluid/light oil concoction overnight
Heat the bejeesus out of it with torch
spray again with WD for a shock cool
heat again
undo
One tip from Terry_T is to give the manifold to head studs a good clout before starting as this gives the corrosion a good shock and helps to break it. Not so easy with the head in situ but with an extension bar you should be able to do this to a good few of them
PostPosted: Sun Jan 06, 2013 11:11 pm
The manifold I am using in my build was also warped and required skimming. It was quite obvious with any flat edge.
