It is currently Mon Oct 06, 2025 5:37 pm
PostPosted: Sun Jan 06, 2013 3:12 pm
Hi there,
Does anyone know off hand the ID of the chargecooler water pipes?
I would look myself but my car isn't here.
Cheers :)
PostPosted: Sun Jan 06, 2013 3:58 pm
not the pipes but the hoses -> ID=22mm, i would guess ~20-21mm ID on the pipes hope it helps
found this on ebay the last time if it is interesting for you
http://stores.ebay.at/Stoney-Racing/_i. ... 2269461013
PostPosted: Sun Jan 06, 2013 8:47 pm
Just measured the OD of the ST205 charge cooler coolant pipes at 22mm. Hope that helps.
PostPosted: Sun Jan 06, 2013 9:01 pm
Sunny, Don,
Thanks very much - was that the hard pipe or the rubber one you measured?
PostPosted: Mon Jan 07, 2013 12:00 am
Just to confirm I measured the OD of the metal charge cooler pipes on one of my spare ST205 charge coolers, NOT the rubber hoses :D I would imagine that new hoses would have an ID of ~20mm?
PostPosted: Mon Jan 07, 2013 12:06 am
Cheers :)
PostPosted: Mon Jan 07, 2013 12:25 pm
i was able to measure a hose and it has 22mm
PostPosted: Mon Jan 07, 2013 2:18 pm
Thanks both! :)
