It is currently Mon Oct 06, 2025 7:25 pm
 Post subject: CC Pump seals
PostPosted: Sun Jan 06, 2013 11:10 pm
Hi folks,
Been a while. Good to see the DC is still ploughing on!
Does anyone know if the chargecooler pump (RC) water seals are available as a replacement part? I stripped and rebuilt my pump&bearings and saw nothing wrong with the seals but mines now a bit leaky and I don't fancy the cost of a new (or used!) pump when this one otherwise works just fine.
Any help appreciated.
 Post subject: Re: CC Pump seals
PostPosted: Sun Jan 06, 2013 11:33 pm
The EPC lists a single assembley :(
I think you'd have to head to your local bearing supplier with the old one and peruse the oil seal catalog until something leaps out at you
Or perhaps browse the likes of SKF online to try and find a match
PostPosted: Sun Jan 06, 2013 11:58 pm
Bah, im sure I'd seen someone somewhere had done it already. Ah well, looks like a catalogue-trawl! Cheers
PostPosted: Mon Jan 07, 2013 1:07 am
I had a quick look round Kris' website but didn't see a seal change. The only other person I know who rebuilt a pump is Dice man but I don't think he changed the seals
PostPosted: Mon Jan 07, 2013 10:57 pm
No I've not found the info anywhere either despite hunting and using magnifying packages on images! Looks like I'll just have to pull it off and strip it down again before getting the parts in, no major problem. Thanks for looking though!
PostPosted: Tue Jan 08, 2013 12:32 pm
No seal change here, I just did the bearings and brushes.
