It is currently Wed Oct 08, 2025 9:20 am
Post new topic Reply to topic  [ 175 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11, 12  Next
PostPosted: Tue Jun 04, 2013 8:55 pm
Car is finished and on the road again !
Put the hood back on on saturday and did the first test drive followed by a bigger one on sunday with the target Nürburgring. Didn´t drove on the track as I want to test out the car a bit more befor as there was minor changes done.
But even now I can say the project was a sucess and I did the right choice of parts and mods.
-The used power steering and chargecooler pumps work decent
-The cooling system is more bored than stressed
-The non organic clutch is halfway usable on public roads
-The ST205 gearbox with it´s differing ratios works as I hoped
-The minimal mid range jerking is gone due to the new ignition parts
-The custom builded turbo works as good as the stock one in lower RPM range and bring much more output above 5000 RPM. I even interupted the high speed test I´ve done on my way home as I was a bit scared of the car. Speedo needle had far passed the final mark at 260 km/h and the car was still pulling strong without a drop in boost. :shock:
PostPosted: Wed Jun 05, 2013 12:58 am
Well Done! Sounds like it all mostly went to plan. The Exedy Hyper Single six puck cerametallic clutch sounds like it is a bit difficult to drive on the road?
PostPosted: Wed Jun 05, 2013 6:47 am
Not so bad as I was feared of. Needed pedal force is equal to stock. In fact a bit more precision is needed in footwork at starting from still standing and car jerks a bit at below 10 km/h ,but it's much less digital in use as usually descripted.
PostPosted: Mon Jul 01, 2013 1:19 am
Visited a dyno day in Luxembourg with my Allradschlurre on saturday and had a run on the dyno too. Went out fine with agood result. Made 310 HP and 400 Nm on the flywheel at 1.09 Bar boost using only 98 Oktan fuel. Normaly I run 102 Oktan fuel, but I didn't get it in Luxembourg.
Also made a video of the dyno run: http://www.youtube.com/watch?v=JpY1LNLRLwk
PostPosted: Mon Jul 01, 2013 9:46 pm
thats a great result, is that the max. boost you run the turbo?
PostPosted: Mon Jul 01, 2013 11:08 pm
No, that was the peak that was reached on the dyno. My car don't raise the boost like at streetuse while it's on the dyno. At road drive the boost raise to 1.15 bar and get limited there due to the stock pistons.
PostPosted: Tue Aug 06, 2013 8:56 pm
Three german owners of white Celica Carlos Sainz Edition had a minimeet last weekend. We also invited a semi professional photographer we know from the german Toyota-Forum as we wanted to do a fotoshooting.
Here one of the first pictures from that day showing No 1946 (mine, original Toyota Super White 040, now Porsche Firnweiß) , No 2959 ( Wolfgang´s, original Toyota Super White 040 ) and No 2050 ( Marco´s, original Black 205, now Toyota Super White 040 ) :
PostPosted: Tue Aug 06, 2013 9:08 pm
Looking forward to seeing more pictures.
Stephen
PostPosted: Tue Aug 06, 2013 9:33 pm
Great photo. Both of my 205's are in Toyota Super White 040 now :)
PostPosted: Tue Aug 06, 2013 9:40 pm
We took the hole day for the shooting, using multiple spots. There will come much more and much more impressive photos, but they aren´t finished yet. Need some magic of the photographer.
PostPosted: Tue Aug 06, 2013 10:40 pm
PostPosted: Wed Aug 07, 2013 6:22 pm
Cool! 8)
PostPosted: Wed Aug 07, 2013 8:27 pm
Great pic - look forward to seeing the others.
PostPosted: Thu Aug 22, 2013 11:07 pm
Received the next set of pitures out of that shooting:
Will getting even more and hopefully the full res versions in the next days.
PostPosted: Thu Feb 20, 2014 7:00 pm
Wow absolutely amazing car
