It is currently Mon Oct 06, 2025 3:51 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
 Post subject: Re: Best handling mods
PostPosted: Fri Dec 13, 2013 3:50 pm
Trodai wrote:
I think the inner arms are ordinary bushings, the 2 spherical ones are in the hub if I remember correctly, your explanations are better than any attempt I could do, it's what my thoughts are too that replacing the spherical with a Bush would be a down grade. I was wondering about the poly droplinks too I imagine they would have a good bit of ahigher rate of wear over the standard type nut would have a similar effect of a increased roll bar?
Drop links are rod end - again zero 'give' in the required direction. The only thing that would make a merginal difference on the anti roll bar are the 2 bushes that attach it to the chassis.
