It is currently Mon Jun 03, 2024 2:52 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: Borg Warner EFR 6258
PostPosted: Tue Jan 07, 2014 10:58 am
Right, these turbo are quite easy to get hold of now, so this is a reminder to anyone who is thinking of getting one and post results... ;) lol
St205 WRC - Running sweet.
PostPosted: Wed Jan 08, 2014 10:44 pm
i'am pretty sure you will be happy with'em :)
PostPosted: Fri Feb 14, 2014 12:04 pm
Will it bolt onto the standard exhaust manifold with an adaptor plate? What adaptor plate is it that one would needs?
PostPosted: Sat Feb 15, 2014 4:26 pm
you need a adapter from toyota twin entry to T25
we machined one out of 1.4541
if you are not able to get one i can ask my friend to do another one, we also machined the bolts out of the oem high temp strange ones (not shown on the pictures)
you are in need to deck the adapter after the welding
PostPosted: Mon Feb 17, 2014 11:55 am
Thanks for that. What is the reason for the bolt holes if the plate is being welded on anyway? (sorry if this is a stupid question)
PostPosted: Tue Feb 18, 2014 9:20 am
to mount the tourbine housing :lol:
PostPosted: Tue Feb 18, 2014 11:06 am
I see (didn't pay attention to the pictures) So the plate is welded to the manifold, studs tapped into the plate to bolt to the turbine housing..
Can the compressor outlet be easily plumbed into the stock charge cooler?
PostPosted: Tue Feb 18, 2014 12:46 pm
correct, and unfortunetly i dont know, i'am using a corolla wrc manifold which aint use the same turbo position, but i would not count on this
is solved this that way
PostPosted: Tue Feb 18, 2014 12:57 pm
REALLY must teach myself to weld. I have a welder and done a bit but my work always comes out looking like pigeon guano! (still gets through the MOT though...)
Nice heat shield. What material is that?
PostPosted: Tue Feb 18, 2014 2:19 pm
The heatshield material looks like Nimbus G2 to me:
http://www.demon-tweeks.co.uk/motorsport/heat-shielding-protection/nimbus-gii-heat-shield
I have used the same stuff on my car :)
PostPosted: Tue Feb 18, 2014 11:16 pm
nearly right, G1 :)
PostPosted: Wed Mar 26, 2014 12:23 pm
just found that
http://www.fensport.co.uk/Parts/Model_1 ... ory_1/1943
PostPosted: Tue Aug 05, 2014 7:43 am
Any performance results with this turbo? How does it perform?
PostPosted: Tue Sep 16, 2014 12:48 am
Not using this flange if somebody want to buy it from
Me.
PostPosted: Tue Nov 18, 2014 1:52 pm
Sunny
How are you running your water ways as I thought they had to be setup , with entering the lower side of the chra to the higher
like:
http://www.full-race.com/articles/efr-i ... lines.html
Also can you tell me the size of the plugs you used on the anti lag ports of the corolla manifold
