It is currently Fri Oct 10, 2025 2:20 pm
Post new topic Reply to topic  [ 98 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
 Post subject: Re: ST165 project ...
PostPosted: Tue May 20, 2014 12:18 pm
Bit more finishing work ...
Current cars
ST185 RC (daily driver)
ST165 (project)
Previous GT4's
ST205 WRC #2082 - (sold)
ST185 CS #2682 (sold)
ST165 (sold)
ST185 CS #2867 (RIP)
Website
http://www.k1ano.co.uk/
:infinity:
PostPosted: Wed May 21, 2014 4:04 pm
Nearly there now ...
Main hoop platforms ...
Decided to take the side panels out so could finish off the rear strut plates ...
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
PostPosted: Tue May 27, 2014 12:10 pm
Thought I'd prune and tidy up the wiring loom to the rear of the car ...
Then paint the rear cabin and roll cage mounts ...
Some other finishing ...
Some 3mm foamex panelling came today so I can make up some rear trim panels so that is one of my next jobs along with preparing to bolt the cage in finally ...
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
PostPosted: Tue May 27, 2014 1:27 pm
Coming together nicely :)
PostPosted: Wed May 28, 2014 1:15 pm
Made the rear panels ...
Raw materials ...
Template and test fitting ...
Finished ...
While I was at it I also decided to remove some of the old rear seat brackets (just need to re-paint now) ...
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
PostPosted: Mon Jun 02, 2014 12:05 pm
Putting the rear wiring back together ...
Decided to look at making a head lining, made a cardboard template first then cut out of hardboard ...
I have some grey foam to cover this with but I am just playing with ideas at present on this one ...
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
PostPosted: Tue Jun 03, 2014 12:12 pm
Started bolting in the cage proper ...
Then starting the hack the dash ...
Plenty of stowage space for tools and stuff now !
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
PostPosted: Wed Jun 04, 2014 12:13 pm
Finished cutting and test fitting the dash ...
The driver side air-vent needs some modification if it is to be retained so I cut away and used some masking tape to initially seal it back up to test fit, I will trim this a bit more and fibre-glass a new contoured skin so that the vent still functions fully ...
Some more pictures of the dash cleaned up and test fitted ...
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
PostPosted: Wed Jun 04, 2014 1:51 pm
NICE! 8)
ST185 CS #1845
PostPosted: Fri Jun 06, 2014 9:03 am
Experimented more with the headlining and got it to where I wanted with cardboard and scrim foam ...
Was going to use hardboard and a foam backing - it was a bit heavy really ...
So decided to use card from a bike box and covered it in scrim foam...
Fitting was a bit tight, but it worked OK ...
Finally looked at re-installing the front loom and removing redundant wiring such as the radio/speaker wires ...
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
PostPosted: Tue Jun 10, 2014 11:16 am
Continued working on the driver side air-vent with a little more fettling and fibreglass ...
Had to rework the previous attempt as there wasn't enough clearance - so out with the rasp ...
Used some aluminium mesh to provide the best contour before glassing ...
Glassed up and a bit of finishing with the sandpaper ...
Final painting ...
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
PostPosted: Thu Jun 26, 2014 12:41 pm
Still tinkering with wiring but received some toys today - will keep me busy for a few nights ...
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
PostPosted: Thu Jun 26, 2014 12:50 pm
Really looking forward to seeing that lot installed. :)
PostPosted: Thu Jun 26, 2014 10:27 pm
Tried a test fit with the previous owners carbon panel, fortunately it was a toyota ae86 so pretty much a straight fit ...
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
PostPosted: Sat Jun 28, 2014 10:33 pm
STACK ftw :D
