It is currently Mon Oct 06, 2025 10:50 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Tue Dec 23, 2014 11:13 pm
Well I suppose I could just give the company a call, but I may also try the camskill price match as well. How thick is a standard radiator btw? Im away from my car for the holidays so cant check. If it's up to scratch I may just order it in the new year before the engine is reassembled as the best price for a rad that I have seen.
PostPosted: Wed Dec 24, 2014 3:46 am
Just to throw my 2p in, I'd stick with standard from tcb, and will be doing so with mine. Confirm it's the jap spec one which is sightly thicker as I recall.
As said plenty of high power cars have used standard rads. Copper core, lot more r&d done by Toyota vs ebay crap etc etc. Plus you get to speak to the good chaps at tcb :)
If you want it for how they look go for it, if you want to improve the cooling, add a header tank/swirl pot setup.
PostPosted: Sun Dec 28, 2014 11:59 am
Thanks for the advice everyone, I will probably order one from a more reputable parts supplier. Euro car parts only seem to do basic 2.0 litre celica rads. As much as I want to try and save cash where I can.
(edit) just found this http://www.eurocarparts.com/ecp/c/Toyota_Celica_2.0_1996/p/car-parts/car-cooling-parts-and-car-heating/cooling/car-radiator/?203820400&1&feb2433120f18283bfe02dafbb23a266f461304e&000261
Koyo radiator: Core Dimensions 350 X 664 X 25 mm copper core and only £70 odd quid
It says 3sgte on the spec, but also say for vehicles without air con?? not sure why if this is a factor as my one definitely has air con.
Any additional advice on this one would be helpful, as i have moved away from the fleabay item, as much as it is cheap, I certainly don't want false economy.
Cheers
(edit) thanks Animal66 I am looking for a standard setup, not looking for any power gains for the moment, but you are certainly right about Toyota's development of components, they're tough and reliable.
PostPosted: Sun Dec 28, 2014 12:56 pm
Not near a car to measure but pretty sure the gt4 radiator is more like. 40 or 50 mm thick.
PostPosted: Sun Dec 28, 2014 7:42 pm
The way i read that link , its for vehicles with/without a/c ?
2004 Subaru WRX
PostPosted: Sun Dec 28, 2014 9:00 pm
I read it the same, with OR without air conditioning so you would be OK.
Cut and paste from Eurocarparts site below.
Vehicle Equipment For vehicles with/without air conditioning
But, I googled for a review for Koyo parts and this came up.
https://www.youtube.com/watch?v=jTok7pPcUUI
Could be one in a million though????
Who knows?
TCB Parts would be my choice, as I have bought enough parts from them to be confident that if it is not a genuine Toyota part, is as good as the genuine part :D
[color=#000080]ST205 WRC 1994
Hybrid turbo
Apexi AVC-R
PostPosted: Sun Dec 28, 2014 11:37 pm
Just had a look at TCB's offering for the ST205 rad and something doesn't add up. The OEM rad top tank/core is 50mm thick but the AVA core part number TO2200 for the ST205 is listed at 24mm thick. AVA link here: http://ava.web.shphosting.com/techinfo_ ... _pub.lasso
Also, as I think has been mentioned earlier its the same AVA part number for the ST202 but the OEM part number is different.
PostPosted: Mon Dec 29, 2014 10:34 am
Dan bought a 205 rad from tcb, as mentioned earlier, and it was the correct thicker rad. And from memory was about £100. It may be a misprint on their site. Worth a phone call.
PostPosted: Mon Dec 29, 2014 4:36 pm
Well, I think it is fairly clear now that, I should just get a replacement from TCB, rather than go bargain hunting as obviously it's a bit of a mine field of unsuitable products, but at least I now know I need a 50mm core, that certainly helps. Thanks for all the advice.
PostPosted: Thu Jul 23, 2015 11:56 am
So I thought I would ask on this thread as it's relevant and has some of the back story to my needs etc..
So with a rad flush and new coolant, my rad has managed to fight on for nearly a year, with no issues. However having sorted out the underside of the car I want to tidy up the engine bay and replace all the rads and mounts with new/reconditioned or uprated items. This is partly for performance but also aesthetics. They are all dented/rusty and if I get all the body work sorted out, the shabby rads will more than likely catch the eye a great deal more.
For the main radiator TCB will be my first port of call.
However...
What about a Mishimoto rads, worth considering? - (I know I don't need one, but they look good :) )
Where can I find new fan shrouds?-do they come with a new OEM rad?
Where can I get the charge cooler rad?
Oil cooler-Mocul coolers worth it?
New or uprated power-steering cooler?
I'm going to save up for this lot and do it properly, switch to gas struts, cooling panel etc... so anything else I should consider?
Thanks
PostPosted: Thu Jul 23, 2015 10:29 pm
I my self did some back to back testing on and off track, I fitted an ebay 56mm triple core ally rad, witch I thought would help with my over heating when on track, but it did not, in fact it was worse, and on the road for normal driving it was ok but I still was not impressed, then I got a new rad from TCB witch as ally core and copper fins, as not 1 does a full copper rad any more even Toyota could not comfurm that there rads was full copper, but with the TCB rad my temps on and off track came down by 5-10c over the ebay 56mm ally rad, so now I only use the TCB rad, with the ebay rad on track temps were 100-110c but with the TCB rad temps were 90-95c tops, and on the road the ebay ally rad was 90c but with the TBC rad 80-85c, and as been said, fensport ran a stock rad to 500bhp+
BRD Page
http://www.brooks-brd.co.uk/
PostPosted: Sat Jul 25, 2015 8:11 pm
have to say my brothers Koyo rad seems to do a good job with his forged engine and 3071 at 2 bar boost.
In saying that I run the stock core and that also works perfectly fine on my car albiet at only 1.2 bar boost
PostPosted: Sun Jul 26, 2015 4:47 pm
Ok so thanks for the feedback on the main radiator I don't think I will be going any where near 500bhp any time soon :). I will stick with stock.
But what about the other bits. Fan shrouds, CC radiator and power-steering cooler, oil cooler where is best to look for these parts?
Thanks
PostPosted: Sun Jul 26, 2015 5:08 pm
stick to stock fan and shrouds if you can, this is my set up, RC fan on the left and St205 fan on the right all on a stock radiator
BRD Page
