It is currently Fri Oct 17, 2025 5:15 pm
Post new topic Reply to topic  [ 106 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Tue Feb 19, 2013 1:45 am
Good & bad news.
Ecu is still displaying the symptoms. No engine light, intrercooler running, no start. As least we know It's ecu at fault.
PostPosted: Tue Feb 19, 2013 6:20 am
At least that's a step forward. Can the ECU be inspected further?
PostPosted: Tue Feb 19, 2013 8:26 am
Oh well :) Starter for 10 then.
Keep at is mate....whatever it takes.... within reason! Ta.
Previously a UK WRC & a CS :)
PostPosted: Tue Feb 19, 2013 9:44 am
Thats a bummer :( What causes the components on the board to fail? Is it just old age or can moisture, condensation etc. result in corrosion where the components are soldered to the PCB?
PostPosted: Tue Feb 19, 2013 10:26 am
Is the ECU different on a CS to a standard 185?
Just thinking TCB may be able to help?
[color=#000080]ST205 WRC 1994
Hybrid turbo
Apexi AVC-R
PostPosted: Tue Feb 19, 2013 11:25 am
Given the 20 year lifespan it's sort of end of life but since Chris has seen more than 1 failure of the same component it does seem that that life is shortened.
It's been a while since I looked at MTBF figures but dim memory suggests about a million hours for a typical electrolytic and it's unlikely to be close to that. IIRC Jeff's car has done best part of 200k miles which suggests less than 20k hours. So it is an early failure
Probably a sign that it's being used in the upper ranges of operating conditions which is having an adverse effect on rated life. Or possibly it's a sign of a downstream problem - sticky idle valve causing larger than normal voltage spikes on the line for eg
Additional diagnosis of Jeffs might reveal more info
PostPosted: Tue Feb 19, 2013 12:13 pm
Cs is different to normal 185, mapping completely different apart from anything else as it has bigger turbo and bigger AFM.
An RC one can be persuaded to fit, but I gather idle control works the other way round.
Since I think it's decoupling on the idle solenoids, I would guess ripple current is above what a 10uF would normally be expected to handle.
I would hazzard a guess that the capacitor failure has put a load of electrical noise on the supply to the rest of the circuitry and has zapped a semiconductor. I'm not optimistic but I will continue trying to diagnose.
Meanwhile, worth asking around for a spare CS ecu, or possibly an RC.
PostPosted: Tue Feb 19, 2013 12:14 pm
AFAIK the CS ECU is different, not least due to the driver for the chargecooler.
PostPosted: Tue Feb 19, 2013 4:36 pm
EEEEeeeek! thanks and all that but all I can find is http://www.ebay.co.uk/itm/350699386519? ... 1438.l2649
£500+
Is it sure the RC is the same as CS?
Maybe time to go aftermarket or whatever???
Anyone breaking a CS?
I'll ask around :(
PostPosted: Tue Feb 19, 2013 11:17 pm
Stick some wanted posts up.
Don't rush and pay loads as I haven't given up on yours yet.
PostPosted: Wed Feb 20, 2013 8:28 am
Will do.
Thanks.
Keep me advised, cheers.
Can you remind me what the part number is please?
PostPosted: Wed Feb 20, 2013 10:43 am
I know its not original but if an RC ECU needs re-jigging and CS ECU is megabucks then why not consider a ST205 ECU conversion? It may not end up being that much cheaper than a budget aftermarket if you pay someone else to do it though.
PostPosted: Wed Feb 20, 2013 11:14 am
Thanks. I will have to consider all options the end of the day:)
I'm glum :(
PostPosted: Wed Feb 20, 2013 8:14 pm
We have a few spare ST205 ECU's in the DC collective but I have idea if its feasible to use them on an ST185CS?
PostPosted: Wed Feb 20, 2013 11:12 pm
It is a bit of a mission when you get into the detail but parts are readily available.
You need 540cc injectors (St205 cams IMHO for sensible fuelling), Map sensor, IAT sensor and some wiring joggery pokery.
Users browsing this forum: No registered users and 161 guests
